Old 24th April 2011, 03:31 PM
Deanno's Avatar
Deanno Deanno is offline
Default Mushroom Dimesions
Hi does anybody know the dimensions for the mushrooms?
I have a few days where the boss is away and would like to get them done?
Many Thanks
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 24th April 2011, 04:54 PM
Andy_B Andy_B is offline
Should be a PDF attached to this if i have done it right !!
Old 24th April 2011, 05:15 PM
Deanno's Avatar
Thank you
that is spot on.
one thing, on the ridge around the top part that sits on the top of the hub why has it got 3 notches taken out?
Thanks Again
Old 24th April 2011, 05:23 PM
the 3 notches are for a "c" spanner to turn the mushy to where you want it .....a bit like the spanner from years gone by to dismantle a bicycles crankshaft you dont really need em....and you dont need the very shallow taper just make as a turret the critical dims are the taper which is 3 degrees and the outer dia for the sierra hub carrier which is 45.5mm get them two right and you will be ok
I have made several styles before just check some of my other posts
this is how I make them now
Old 26th April 2011, 11:27 AM
Deanno's Avatar
just a quick question what are people making them out of?
and how did you get the taper? was it using the hand reamer used for the lower ball joints?
Old 16th June 2011, 12:33 PM
Deanno's Avatar
does anybody know, when doing the hole through the top i've noticed that it is a 3 degree shamfer how is this done? can it be done using the tapered reamer used for the front uprights?
Dean
