![]() Maybe if you buy on ebay they will post to you.If not why not try Saturn im sure they would help you.
http://www.saturnsportscars.co.uk/# http://www.saturnsportscars.co.uk/st...ewCat&catId=11 |
![]() Yes I was thinking that and there was a guy I don't remember his name he posted the links to the ones on ebay so ya ill look into it thanks
![]() maybe try and get the track rod ends,maxi ball joint and transit drag links from the same supplier to save on postage.
If you get stuck because they will not post outside uk send me PM and i will give you uk address. |
![]() Thanks a lot if I get stuck I will send you a pm. Thanks
![]() all model Sierra rack/track ends, ball joints etc can be bought from Midas, Autoquip, Autozone, Spareslink and most other non franchised motorspares outlets...
![]() Sierras are a dime a dozen at the scrap yards and they practicality give the bits away for next to nothing since nobody drive Sierras anymore and the wrecks are taking up space. BTW, have you started on your frame yet? My car is built and stripped, chassis off to the sandblast / paint guys on coming Friday and next week I will start to put it together finally. And still I have not steering rack clamps or rack-end connectors...will worry about that when I get there ![]() Last edited by Wynand : 10th May 2011 at 06:22 PM. |
![]() I been looking in few places for the ball joints austin maxi no one do those ball joint and the ford transit drag link ends I don't have part numbers for any no one do that to. do you any part numbers Cause that will help cause uk numbers not the same .the tie rod ends that I can get and the rack. I'm sorting out space but got some things already
![]() Check your emails Ricky.
Be Lucky, Mike. ![]() |
#18
![]() I got it thanks ill be taking a look at it now
#19
![]() Quote:
I bought two from Brad at Locost SA as he is importing them - Cost R450 a pair plus postage. I had the part number - is QH.... will look on the box tomorrow for the part number, but at the end it will cost more to import than to buy from the Locost guy. The ball joint cost about 9 pounds each if im not mistaken (I found them in England when I was searching at the time) but the postage is the killer but still wayyy over the R450 + R70 postage I paid for a pair and the risk of not receiving them ![]() |
#20
![]() Ya I will contact locost sa and see if he will deal with me cause the last time I asked him about the steering bush kit he said he did not have now I'm not sure he is lying or not cause when I asked him about importing locost parts for haynes he turned me down flat and said he don't do anything for the haynes locost
