Old 11th May 2011, 11:16 PM
Ashtonr Ashtonr is offline
Default Dodgy Welding
Well had a great night tonight nearly finished my roll bar but cocked up one of the welds on the seat belt mountings right in the corner between the threaded insert and the cross member. Has anyone got any good ideas on how to remove unwanted weld where a grinding disk is not accessable ? If not guess I will have grind the whole thing off and start again
Old 11th May 2011, 11:34 PM
Andy J Andy J is offline
A die grinder would get in there
AJ'S Build
Old 11th May 2011, 11:52 PM
KAMBO KAMBO is offline
as andy has suggested a die grinder or a dremel
Old 12th May 2011, 08:45 AM
gaz05 gaz05 is offline
As said, a Dremel. I had a blob run on an upright weld and though sound it looked awful. Takes a while with a stone on the Dremel but definitely worth the time.
Total cost so far
Materials £3,150
Tools £855
Old 12th May 2011, 11:08 AM
Thanks guys looks like I need to buy a Die grinder just to get the bits. Will give this a try as its preferable to cutting off the braket
Old 12th May 2011, 11:49 AM
You should be able to buy the stone you need and put it in a drill. Die grinders arnt cheap if you only need to grind one mistake
AJ'S Build
Old 12th May 2011, 04:56 PM
rotery burr in the drill as drills are a bit slow for stone bits
Old 12th May 2011, 11:27 PM
Well after destroying several grinding bits probably because the drill doesnt rev quick enough the dodgy weld now looks better than all the others. Many thanks for your help, as always if you know the name of the tool you actually need you can normally sort the problem
Old 13th May 2011, 10:35 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
i have an air die grinder that i will make available to anyone that needs it just drop me a pm and i will post it on to you
