Old 14th May 2011, 10:21 AM
MarkB MarkB is offline
Default LMPesque
All but got a full set of moulds for an old super sport race car along the lines of the early Mallock, they are no longer used as the car they were used on has been up dated.
I was taken around Silverstone in this car in 2000 and bugger me it was scary but exciting,the acceleration and braking power was mad it felt like you were being forced thru the belts when braking then being ripped out when the bloke accelerated...3 laps was enough for my stomach and I couldn't undo my crash helmet when I got out as shaking so much so had a fag thru the visor
If it's worth a punt I may do it?
Old 14th May 2011, 10:46 AM
Where's the pictures at
Wouldn't mind seeing a full body option for the Roadster tough
Old 14th May 2011, 10:54 AM
TSM Locost's Avatar
Good to see Ronnie has his enthusiasm back. cant find any pic's on the net.
Pic's please mark if only of the moulds to get some idea of the shape.
Be Lucky, Mike.
Old 14th May 2011, 10:56 AM
Google National Super Sports which is run or was run by the BRDC
Old 14th May 2011, 11:21 AM
That's quite funky mark
Looks to have quite a wide wheel base ( Probably a trick of the eye )
I can imagine just how well that would handle.
Old 14th May 2011, 06:52 PM
The other snag is, it's mid engined
Old 14th May 2011, 07:39 PM
Only a snag if you let it be,just what has been mentioned about previously a can am styley body.
Do it
How much do you reckon ?
Old 14th May 2011, 07:59 PM
Talking Brings a tear to my eye
Do you mean that body shell would be a problem fitted to the Roadster Mark
If I had to fit the seat in the middle, I would have a gear stick right up me jacksy
Old 14th May 2011, 09:12 PM
It's a two seater honest
Bit of filler here n there should have it the right size
Old 14th May 2011, 09:24 PM
Get glassing..........
