Old 17th June 2011, 07:50 PM
misty misty is offline
Default battery cutoff switch
Hi All
How do you wire the cutoff switch any help would be great thankyou
Old 18th June 2011, 01:49 AM
erm... possible ways is that you either interrupt your negative as in instead of providing a direct earth you bypass it with a batt cut off or instead of getting a direct positive to the starter you do it via the switch ?
just a thought
Michael
Old 18th June 2011, 07:09 AM
If it's for Motor Sport then check the rule book.
If interrupting all power ( including the starter ) then make sure it's a BIG cutoff.
