Old 18th July 2011, 06:30 PM
will_08 will_08 is offline
Default tub tubes
after making an arse of my tub tubes rp1 etc with a plumbers pipe bender, i then thought an electricians conduit bender would be more suitable,
then.... i thought is there any good reason why i just cant use 20mm electrical conduit for these tubes?
Old 18th July 2011, 06:35 PM
Jimmyd Jimmyd is offline
Don't see why not but they are usually galvanised so make sure and remove it in the area you plan to weld. I believe it gives off nasty fumes.
J
Old 18th July 2011, 07:39 PM
Not sure about using conduit, but I did use a 20mm conduit bender to bend my tubes.
It didn't make a perfect job of them, and flattened them slightly, but it's good enough considering the ali tub is going to cover them.
Old 18th July 2011, 08:04 PM
Thanks for the input guys, i might retrieve the tubes and give them go in the conduit bender.
Cheers Will
Old 18th July 2011, 08:33 PM
Deanno's Avatar
Deanno Deanno is offline
any input is good as i'm using 20mm conduit some contractors left for me when they did a job, i told them i was building a kit car and asked if they had any off cuts 10 mins later he had to order 2 more lengths and a pack of 6 lengths turned up and he said it yours if you want it. bonus
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 18th July 2011, 10:03 PM
james3004's Avatar
I used a conduit bender but packed the dies out with some duct tape to make the tube a bit more of a snug fit, It didn't work out to badly
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 19th July 2011, 08:59 AM
Talking
Dont suppose using conduit is a problem but dont use the galvo stuff as fumes when welding are toxic. Also galv <zinc> plays havoc when it comes into contact with ally.
Old 19th July 2011, 10:06 PM
You could of course just go buy a length of 7/8' 16-14gauge ERW clean mild steel then you'll have no trouble welding or bonding to it.
Old 19th July 2011, 10:42 PM
true, but the conduit is free!
Im not a glaswegian for no reason
Old 20th July 2011, 06:50 PM
Deanno's Avatar
I'm using 20mm conduit (Again for free) and have just done my bends today, what I did was cut 4 pieces about 1m long then where it says in the book the measurement BEFORE the bend add a bit extra.
I now have 4 90 degree bends which I intend to join by means of an insert into the pipe and weld fully ensuring I grind the galv off and use a mask when welding.
alternatively buy the ones on ebay
