Old 21st July 2011, 02:56 PM
Looks really good, my mind is back on the build now after a little break. I was thinking as I still have my donor I was going to cut out the section of tunnel that the handbrake mounts to and weld it into my chassis tunnel with a bit of fetling. But failing that it looks really simple to mount otherwise!
Have you got the engines final install height now?
Old 21st July 2011, 05:11 PM
Yep, I've got the sump flat on the table and raised the chassis 40mm above it.
I don't like the idea of the sump being that low below the chassis, but if I raised the engine any higher it wouldn't fit under the bonnet.
Height-wise it's going to be pretty blooming tight as it is. I haven't got a bonnet yet, but if I put the scuttle and nose cone in place and put a straight edge between them it looks like the bonnet will just skim the intake manifold.
I'm guessing/hopeing that once the engine mounts take the weight of the engine they'll compress slightly leaving me a mm or two clearance!
Old 22nd July 2011, 08:44 AM
If there is any clearance whatsoever then your engine isn't big enough!!
Old 22nd July 2011, 09:13 AM
Good point!
In fact there's tons of clearance on the passenger side of the engine bay, I'll have to fill it with a mahoosive turbo
Old 22nd July 2011, 07:06 PM
sven8t4 sven8t4 is offline
Ooooooooh Good Plan..... I was thinking post SVA of a Supercharger? Ex BMW '0 Series' aka Mini....
Cost So Far = £376.62
I LISTEN TO THE VOICES IN MY TOOLBOX
Old 22nd July 2011, 07:18 PM
Eaton M45,
I used to have an M62 sitting on my desk many moons ago.
Old 23rd July 2011, 07:36 AM
Stop planting ideas into my head, I just spent a couple of hours looking at different charger options.... must resist... at least until after IVA anyway!
Old 23rd July 2011, 08:18 AM
Smile
Good point!
Or an extra 4 cylinders.
Old 25th July 2011, 01:37 PM
Thought I'd have a go at mounting the gearbox last week.
I'm not sure I'm quite happy with what I've done, but I can't think of a better way...
After a lot of umming and arring I made something sort of like the main engine mounts, but smaller, and using a rubber engine mount from a classic/original mini.
First I tacked a plate onto the base of the tunnel with the mini mount attached:
Then I bolted a plate onto the top of the mini mount, and another on onto the bottom of the gearbox, and tacked in a couple of plates between the two.
Finally I removed it, added some sides and fully welded and this is what I ended up with:
And here it is back in the chassis:
Does that look like a vaguely sensible way to do it?
Old 25th July 2011, 02:06 PM
I have no idea!
