Old 24th July 2011, 06:46 PM
Deanno's Avatar
Deanno Deanno is offline
i've set up a blog on wordpress the same as leroy brown but i've yet to update it well to be honest i've yet to start it
well in 3 weeks when my little man finally meets his mummy and daddy i'll have plenty of time in the house so i'm trying to do as much as i can before he arrives.
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 25th July 2011, 01:37 PM
If anybody is interested in a MSA compliant cage with side and rear impact protection specifically built for the Roadster let me know as we are currently talking to a local maker of cages to fit one to the Teamtrain/Saturn race car currently running in Northern Spotrs and Saloon series.
Wont be cheap but will be the dogs bits and first time fit.
Old 26th July 2011, 09:11 PM
John.W John.W is offline
Default Roll Bar
Hi Deanno,
The roll bar looks good, I am planning on doing the same thing but with 50 x 50 mm box steel tube. Is there any chance you can give me the dimensions you used for the 5 main pieces?
Regards
John
Regards
John
www.rallyx.de
Old 26th July 2011, 10:02 PM
Talking segment bends
If you have spare tube it might be worth doing a segment bend.
http://t1.gstatic.com/images?q=tbn:A...-cFQIaMIVxymJQ
A bit more time consuming but a bit nearer a production bend.
http://t1.gstatic.com/images?q=tbn:A...WGQflqPjGJ6_eL
Old 26th July 2011, 11:35 PM
Question What thread
The threads for harness mounts on the roll bar need to be 7/16th imperial according to the book.
However I'm sure I fitted 7/16 unf for the lower mounts .
Some advice please before I fit the wrong stuff:confused
:http://s1189.photobucket.com/albums/z429/ayjay50/
Last edited by ayjay : 26th July 2011 at 11:48 PM. Reason: just remembered I know how to add the link!
Old 27th July 2011, 01:04 PM
SeriesLandy's Avatar
You are correct they should be unf (fine pitch thread)
I asked for 7/16 in my local bolt shop and got coarse, they were a bitch to remove and change for fine nuts after I fully welded the plates in.
Old 27th July 2011, 04:13 PM
Deanno's Avatar
i'm going to wait until i get my harnesses (soon hopefully) and they come with bolts os i'll buy nuts to suit.
Old 27th July 2011, 09:22 PM
Default 7/16 UNF bolts
Hi Deanno,
LandRover do some good seat belt 7/16 UNF bolts with rounded torx heads. I don't know the part No but I will try to find out if you are interested.
Regards
John
Regards
John
www.rallyx.de
Old 27th July 2011, 10:04 PM
Sorry for hijacking your post Deanno
Its ok re unf threads
Ive got some harnesses with bolts provided but I need the threaded inserts to weld in to make the harness brackets . I was confused because the book says
7/16 imp.
I need to find some 7/16 unf threaded inserts to weld in.
Adrian
Old 28th July 2011, 03:03 PM
Deanno's Avatar
John,
sorry I have only just seen your post, I will give you the dimensions when I get home.
Regards
Dean
Originally Posted by John.W View Post
Hi Deanno,
Regards
John
