Old 22nd July 2011, 10:13 PM
gaz05 gaz05 is offline
Default What starter?
I'm looking for a starter motor for my build but not sure which one. I'm going to be running a 2.0L silvertop with 1.8 flywheel and type 9 box. Would I be right in thinking I should be after one from a twink?
Total cost so far
Materials £3,150
Tools £855
Old 22nd July 2011, 10:36 PM
rich's Avatar
rich rich is offline
i have a 2.0l black top with a 1.8 silver top flywheel to a type 9 box.
I managed to find a brand new gear reduction starter that is made to fit a 2.0l sierra pinto. Fits nice and turns over a treat but had to modify the black top sump as the starter fits the opposite side on a focus gearbox.
Ok sounds complicated but most people can supply gear reduction starters that replace the OE lucas starters that do the same job, see my photos
reason for gear reduction, smaller diameter caucus (motor)
Old 23rd July 2011, 12:02 PM
mark mark is offline
Im using cvh starter with mine and a 1.8 silvertop flywheel
Works fine just had to masasage the sump a little for clearance
Old 24th July 2011, 07:42 PM
lucas LRS707 or equilvent
Old 25th July 2011, 08:27 PM
Cheers lads. Looks like I need a CVH one then.
Total cost so far
Materials £3,150
Tools £855
Old 26th July 2011, 07:28 PM
lrs707 type fits cvh sierra cvh, i4 dohc sierra and granada i4 dohc engines
think there is a diesel higher power one that fits but was unable to track down what one it was
Old 26th July 2011, 09:54 PM
I had a diesel one from the donor baz but it was miles out.
Total cost so far
Materials £3,150
Tools £855
Old 2nd August 2011, 09:31 AM
Right then. Anyone got a cvh one lying about that they'd like to sell?
Total cost so far
Materials £3,150
Tools £855
Old 3rd August 2011, 07:36 AM
Be careful, there are two LRS707 models, one is 3.5" diameter, one is 5.5" diameter, and the bigger one fouls the sump. Even then, you may find that the throw on the LRS707 isn't long enough to engage with the ring gear on the flywheel.
I ended up having to become a ford starter motor nerd when researching which one would fit, and in the end an LRS543 fitted mine (2.0l Silvertop with 1.8 flywheel and type 9 gearbox.)
I think the difference comes because ford made a few variations of bellhousing depth over the years, so when you have a real mongrel collection of parts (as I did), things can get complicated.
Hope that hasn't confused the issue too much!
Adrian
My Build Pictures:
Old 4th August 2011, 11:00 PM
Cheers Adrian
Does anyone know which car this came off (LRS543 ). There are loads of starter come up on Ebay that came off a particular car but no code number.
Total cost so far
Materials £3,150
Tools £855
