i've set up a blog on wordpress the same as leroy brown but i've yet to update it well to be honest i've yet to start it
![]() well in 3 weeks when my little man finally meets his mummy and daddy i'll have plenty of time in the house so i'm trying to do as much as i can before he arrives.
My Blog: deannoshaynesroadster.wordpress.com (under construction) Being overtaken is a sign of weakness. South Wales Kit Car Club www.southwaleskitcarclub.co.uk WWW.HELPFORHEROES.ORG.UK XBox Gamer tag: D34NNO |
If anybody is interested in a MSA compliant cage with side and rear impact protection specifically built for the Roadster let me know as we are currently talking to a local maker of cages to fit one to the Teamtrain/Saturn race car currently running in Northern Spotrs and Saloon series.
Wont be cheap but will be the dogs bits and first time fit.
Hi Deanno,
The roll bar looks good, I am planning on doing the same thing but with 50 x 50 mm box steel tube. Is there any chance you can give me the dimensions you used for the 5 main pieces? Regards John |
If you have spare tube it might be worth doing a segment bend.
http://t1.gstatic.com/images?q=tbn:A...-cFQIaMIVxymJQ A bit more time consuming but a bit nearer a production bend. http://t1.gstatic.com/images?q=tbn:A...WGQflqPjGJ6_eL Bob
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 Last edited by robo : 26th July 2011 at 10:17 PM. |
The threads for harness mounts on the roll bar need to be 7/16th imperial according to the book.
However I'm sure I fitted 7/16 unf for the lower mounts . Some advice please before I fit the wrong stuff:confused :http://s1189.photobucket.com/albums/z429/ayjay50/ Last edited by ayjay : 26th July 2011 at 11:48 PM. Reason: just remembered I know how to add the link! |
You are correct they should be unf (fine pitch thread)
I asked for 7/16 in my local bolt shop and got coarse, they were a bitch to remove and change for fine nuts after I fully welded the plates in. |
i'm going to wait until i get my harnesses (soon hopefully) and they come with bolts os i'll buy nuts to suit.
#18
Hi Deanno,
LandRover do some good seat belt 7/16 UNF bolts with rounded torx heads. I don't know the part No but I will try to find out if you are interested. Regards John |
#19
Sorry for hijacking your post Deanno
Its ok re unf threads Ive got some harnesses with bolts provided but I need the threaded inserts to weld in to make the harness brackets . I was confused because the book says 7/16 imp. I need to find some 7/16 unf threaded inserts to weld in. Cheers Adrian http://s1189.photobucket.com/albums/z429/ayjay50/ |
#20
John,
sorry I have only just seen your post, I will give you the dimensions when I get home. Regards Dean
