Old 1st August 2011, 04:54 PM
Tilly819 Tilly819 is offline
Default Iv blown it up!!!!!!
hi all
as the title suggests iv blown up the roadster have not had chance to fully inspect the damage but i judging from the size of the hole in the crank case id say a rod has let go....
not sure of the cause but when i stopped and checked the engine temp it was about 105C so there was a cooling failure which probably was a contributory factor.
Anyway on the upside that gives me the chance to put something different in if i want, i may replace like for like which would cost about £600 or i could swap for the Volvo inline 6 i have lying around which may be a little more expensive and quite a bit heaver but would make a bit more power and would get the dam thing out of the way and put it to some use.
www.heraldic-motorsport.co.uk
Old 1st August 2011, 04:56 PM
jerkins's Avatar
jerkins jerkins is offline
What was the engine that blew?
(and it might have overheated due to lack of oil / friction...)
Old 1st August 2011, 04:57 PM
Danb1987 Danb1987 is offline
Sorry to hear that matey you must have felt terrible! Put the vovlo engine to good use and stick that one in
Built is so much better than Brought!
Old 1st August 2011, 05:04 PM
super blackbird which are admittedly known for having week oil pumps
Old 1st August 2011, 05:16 PM
were you being a little spirited in your driving when it blow?
I've seen a few bike engines with similar failures.
Old 1st August 2011, 05:23 PM
Maybe..........
Old 1st August 2011, 05:32 PM
Gutted for you mate. The first engine I had in mine had the head gasket go, followed, in a close 2nd, by either the rings or valves.... either way compression dropped from 200 psi to 90! Proper pain in the arse changing the engine over but managed it in a weekend on my own.
Old 1st August 2011, 05:47 PM
yeh its a bit of a pain.
couple of issues with the volvo,
1 need a gearbox for it and they are rare as rocking horse s**t
2 will need a stand alone ECU most lightly mega or micro squirt
3 transmission tunnel will require some enlarging
all that said its a good strong engine 2.5 ltr 170HP should see north of 200 N/A when iv finished fiddling with it.
Old 1st August 2011, 05:53 PM
Better of with a white block T4 , you still need the M90 Box though.
Old 1st August 2011, 05:54 PM
all in a days work for a capable kitcar builder.
