Old 5th August 2011, 07:33 AM
I would lower the engine mount, mine clears fine on the CVH.
Old 5th August 2011, 09:08 AM
Steve, just a thought, you havent used a big fat rubber engine mount that has lifted up the engine have you??? it would not take much of a lift that far back to raise the shaft at the front.
Old 5th August 2011, 09:21 AM
SeriesLandy's Avatar
TT I think making a new engine mount would be the cheapest solution.
No its all standard, as per the book. Did chris change things in it but forget to actually mention what was done? I can't seem to find a decent photo in the book how the steering column is made.
Old 5th August 2011, 09:50 AM
Modding an engine mount to clear a steering shaft is preferable to modding a steering shaft to clear an engine mount. The less complicated the steering system the better.
Old 5th August 2011, 10:53 AM
would save having an extra load of uj's in the system. Would 40x40 or 30x30 be preferable for the pinto mount?
Old 5th August 2011, 06:52 PM
Will try and get you a pic of my mounts tomorrow.
Old 6th September 2012, 01:53 PM
jps jps is offline
Having similar problems - using a Pinto with the Sierra rubber engine mounts - the steel mounts that go on the chassis rails are book spec, I trial fitted the engine for the first time last weekend - but the steering shaft wants to run through where the engine mount is now...
Don't want to drop the mounts - as I don't want to loose more ground clearance / create any problems with the prop alignment...
Old 6th September 2012, 03:17 PM
I ended up ditching the sierra cast mount and making out out of 5mm plate and a bit of tube.
