Old 6th August 2011, 07:21 AM
misty misty is offline
Default tub cover
just trying to make the tub cover in alum sheet but how do you make the corners fold over the rear neatly any ideas would be geat
Old 6th August 2011, 07:27 PM
Deanno's Avatar
Deanno Deanno is offline
you could try cuting a peice of wood about 1" thick putting a radius on it then using a wooden mallet beat it round??
just an idea, well thats how i would do it.
hope this helps.
pictures of how you do it would be nice to see.
Regards
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 6th August 2011, 07:49 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
find someone to lend you one of these
http://www.frost.co.uk/automotive-bo...-slappers.html
Old 6th August 2011, 09:01 PM
Ricky Ricky is offline
Smile tub cover
Hi guys how you doing I just red the post regarding the tools you can use I'm not sure if there are DIY spoons but slappers there are if you take a old file with a broken handle "flat file" and bend it to look the same as the ones you can buy and then using one of those flat sanding disks on a grinder you make the file smooth and then you can use that as a slapper it works the same as the ones you buy
Old 6th August 2011, 09:06 PM
You need to start with a few sheets of paper before you start cutting ali sheet. Tape a sheet of paper so that 40mm of sticks above the top of the tube line, mark the edges of the paper on the tube so you have a reference point. You need to reduce the height of the section that goes around the corner by 10-15mm and cut small accute triangle shapes in the cut down section. When you can fold the paper over the corner with out it over lapping the next triangle along you have got it correct. Remember sheets of paper are a penny a sheet, ali on the other hand is not. Don't be tempted to use a bare hammer to bend the ali over as you'll just end up with unsightly dents, use a length of pine as a dolly and work it over in 3-5deg bents back and forth untill the job is done.
Old 7th August 2011, 09:17 AM
mark mark is offline
Files snap like carrots in my experience! not sure you could bend one without heating it up, just a comment incase anyone tries it so they dont end up with a piece of file stuck in their face
Old 9th August 2011, 05:06 PM
here here file bending is not safe!
one of my old bosses used to have one made from a old heavy duty tyre leaver fashoned to look like a shoe horn
