Old 14th August 2011, 10:53 AM
1.baz-r (std t9 41mm hole)
2.vmax1974
3.
4.
5.
6.
7.
8.
9.
10.
Old 14th August 2011, 10:59 AM
Originally Posted by robo View Post
Whats the latest on this? Is someone going to be making book versions of the pedal box? Sooooooooooooooonish?
Also need to know how to tell the difference between a type 9 gear tunnel and the other version. What i have works for me but i dont know what i have.
the mt75 is thinner in the foot well area there is details in the amendments section
Old 14th August 2011, 11:39 AM
mark mark is offline
The clutch pedal definately needs to be 5mm regardless of clutch set up, its fine until you push it at a slight angle and then it would fold over like a piece of cardboard!
Old 14th August 2011, 11:52 AM
Would agree with Mark there Baz, when you get these cut have all the pedals in 5mm but the clutch will definitely bend in 3mm. The ones i sent you where in 5mm and are a lot stronger.
Hope you don't mind me saying......Andrew
Old 14th August 2011, 12:23 PM
ok option is i can get a requote for 5mm clutch arms or we dobble up the 3mm and weld together ones to make 6mm
looking at the costing of the 5mm bits it would work out about the same.
this is all simple to sort my main issue is to get takers for all 10 sets
im also looking for some roll bar plates for the seatbelt mounts and zetec engine mount plates and an inlet plate if i can get a dxf for it
anyone want some?
Old 14th August 2011, 12:35 PM
brainbug007's Avatar
Ok I'll measure up my master cylinder later this afternoon as no idea what size it is.
Old 14th August 2011, 12:47 PM
if it has a step in the bit that goes in the bulkhead its the bendix type (big hole)
the other type is lucas (small hole) it hoping it could just be fitted inthe bigger hole
email sent out for 5mm clutch pedal btw
Old 14th August 2011, 12:51 PM
Ok, ill take a picture as that might make it easy for you to identify and i'll take some rough measurements. I'd prefer all the pedals in 5mm if possible & happy to pay a bit more for it.
Old 14th August 2011, 12:58 PM
email sent for thicker clutch im sure you dont want a 5mm throttle pedal do you? i have one you can have if you realy want its a bit overkill for me
Old 14th August 2011, 01:23 PM
bendix type big hole all orignals have step in end there are mor than one type but all take same hole as far as i can tell. some have ford cast in the side
41mm hole needed
lucas/girling smaller hole can be steel tube (not cast) all have thinner straight end dont know hole size but is smaller
