Old 17th August 2011, 10:18 AM
Peter-C Peter-C is offline
Default Is this ok for IVA
I've just started to join the flexible brake hoses at the front to the copper tubing inside the car. I've noticed that the copper tube is directly beneath the alternator but not touching - actually about 20 mm between. Does anyone know if this is ok.
Hopefully the attachments might help.
Pete
Old 17th August 2011, 11:13 AM
Depends on the tester I guess. He might assume the engine could move enough to come into contact with it (which it never should!) I'd just pop an 'S' in the line to give it more clearance. If your concerned over something, don't be surprised the tester might also be concerned.
