Old 22nd August 2011, 05:16 PM
MikeB MikeB is offline
Default Disposing of Disposable CO2 bottles
I seem to have collected a large number of these from my 2 chassis builds.
DOn't think my local tip will take them as they are "gas bottles"
What are the options, would a scrappy take them they weigh a fair bit each so might have a bit of value in them?
Old 22nd August 2011, 05:18 PM
brainbug007's Avatar
Heh I know you shouldn't but I put mine out in with the normal rubbish... Taking them to the scrapy is a good idea though as they must weigh a kilo or two empty and £1.80 a kilo helps pay for the gas
Old 22nd August 2011, 05:56 PM
TSM Locost's Avatar
Chop the tops off and weigh them in for scrap.
Be Lucky, Mike.
Old 22nd August 2011, 06:06 PM
I drilled holes in mine and weighed them in, every penny counts
Old 22nd August 2011, 06:11 PM
so whate the deal with weighing them in.
Do they have to have a hole drilled in.
Think I have about 12-14 of them lying around.
at 1.88 assuming about 1.5kg each for 12 thats errmmm £34!
assuming its no massive hastle finding a scrappy near wellingborough!
Old 22nd August 2011, 06:58 PM
If they are empty then the valve will be loose, and as it's an inert gas there is no chance of vapour being an issue.
£1.88/1.5KG that's £1253/T who on earth is payin that for Mild?
Old 22nd August 2011, 07:22 PM
I think there has been an error in the maths there
Heavy steel/iron is fetching £260 per tonne in these parts, that's 26p per
kilo
FWIW
My local scrappy will not take any kind of gas cylinder under any circumstances.
The local re-cycle centre will take all types of gas cylinder ..... They just put em in a cage, no idea where they go from there.
Old 22nd August 2011, 07:31 PM
39p each then, you could lop the top and bottom off to take them to the scrapper.... But by the time you have destroyed the hacksaw blade your down to pennies, then the fuel your into negative figures...
Old 22nd August 2011, 09:30 PM
I'd keep them for bits n bobs like decat pipes/ slit, open a little re-weld into a prop catcher,/ exhaust piping....you never know ....how can tell I'm a hoarder
Old 22nd August 2011, 09:39 PM
You sound like me Kev ...... tight or should I say " careful with the pennies "
Must be a NERD thing
