Old 25th August 2011, 08:40 AM
Aussie_Haynes_MX5 Aussie_Haynes_MX5 is offline
Originally Posted by ozzy1 View Post
MX5 here are stupid money also,even a piece of Cr@p.Also there is the stipulation in building a car that you have to use an engine from 1999 or newer or you can go for an emissions test at a cost of $4k and take your chance
$4k for an emissions test? In NSW they are running the IM240 for free in Botany. If you believe that your car might not pass the IM240 the RTA (Roads and Traffic Authority for you guys outside Australia) they actually give you the opportunity to bring it down to the rolling road and get it tested. If it doesn't pass then it's not actually a defect. They give you advice as to how to fix it and you can take it or leave it. Finally a bit of sensibility from the RTA.
