Old 25th August 2011, 04:03 PM
brainbug007's Avatar
Default Pipe Clips
Are these cheap clips good enough for securing things like electrics, fuel, & brake lines from an iva standpoint?
http://www.screwfix.com/p/snaplid-cl...k-of-100/75018
Old 25th August 2011, 05:20 PM
For brake pipes & copper fuel lines I used 8mm nylon 'P' clips riveted to the chassis.
http://www.ebay.co.uk/itm/20-x-8mm-5...em51861 85364
All the cabling is in conduit which is cable tied through rivet on bases.
http://www.ebay.co.uk/itm/50-X-CABLE...item415c035bbc
Old 25th August 2011, 07:03 PM
I have always used this type of split conduit and clips for wiring in the engine bay . They are really neat and as you remember stuff and add things just open the clip slide in another wire and pop it back in,
http://www.thetoolboxshop.com/0-326-...nw75-965-p.asp
When you need a cable to exit the conduit just put a small hole in it on the other side of the split. when 100% done just tape in shut every 300 mm .
