Old 27th August 2011, 06:03 PM
Part of the drive hub has possibly detached after a few hard take off's,the springs in the center sometimes come out.
Old 27th August 2011, 06:30 PM
aerosam's Avatar
aerosam aerosam is offline
Originally Posted by geeveejay View Post
Intresting problem. I am not familar with the set up on the BMW motor. But once had similar issues with a Ford CVH powered Scimitar. Turned out to be the pinion bearing collapsed. Could account for the clunk in the bell housing when you rock it
Umm, dull question time....
What's the pinion bearing?
Old 29th August 2011, 06:12 PM
its a bearing for a pinion silly
Old 29th August 2011, 06:37 PM
aerosam's Avatar
Ok, got the engine out this afternoon (what else are bank holidays for?) and although I haven't removed the clutch from the flywheel yet, it looks like whats happened is sudden and complete failure of the friction plate. There are bits of disintegrated friction material in the bellhousing, and chunks of it sticking out of the side of the clutch assembly.
I've got a new clutch ordered which will be here on Thursday.
Old 1st September 2011, 04:15 PM
aerosam's Avatar
Well, finally cracked it.
Pulled the clutch off today, and found that one side of the friction plate had lost all of it's friction material, which was piled up in the bellhousing and on the floor.
New clutch was due today, just found out I won't get it till Monday, great. In the meantime, there's lots of pics on my blog.
Old 1st September 2011, 04:17 PM
aerosam's Avatar
Old 1st September 2011, 04:48 PM
I reckon that its lost all of its newness Might pay to upgrade to a hd unit
Old 1st September 2011, 09:45 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
Heat has broken down the binder and the fibre element has been spun out into the bellhousing. I am dealing with at least 2 a month of these, quite often with people towing boats down to Cornwall and then launching the thing and cooking the clutch in the process.
I suppose the gander of a trackday could have the same results. A HD clutch has less friction material so is more likely to fry, not less.
Old 1st September 2011, 10:00 PM
jerkins's Avatar
jerkins jerkins is offline
I hope it was the cover plate side (it looks like it) - otherwise you'd be looking at a flywheel skim...
Old 1st September 2011, 10:09 PM
Question
Sod it does that mean the hd competition clutch kit i bought that can handle 70% more torque is not as good as the standard unit???????????
