Old 6th September 2011, 06:34 PM
Got to say that i build my own tank from mild steel 2 years ago to similar to the book dimemsions.
Painted in red oxided and hammerite and it looks just as good as it did the day it was fitted and was pretty cheap compared to buying an aluminum one.
Thinking about it now, the only change i would consider would be larger.
Old 7th September 2011, 07:11 PM
sven8t4 sven8t4 is offline
ayjay long range book tub
skov long range book tub
KenK long range SSC GRP
Dan_g8 long range SSC GRP
Shaun - long range SSC GRP
Sven - long range SSC GRP (MX-5 Sender and pumphole?????mayyyyyybe)
Cost So Far = £376.62
I LISTEN TO THE VOICES IN MY TOOLBOX
Old 7th September 2011, 08:16 PM
Just the tank. Wasnt sure if the semder/pump hole is precut?
Old 7th September 2011, 08:22 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Originally Posted by Ashtonr View Post
I recently spent a fair amount of time researching fuel tank suppliers and I was consistantly told not to use Mild steel as it rusts most of the suppliers I talked to recommended Stainless or Ally only
Have a look at my powder coating system group buy saving 40quid ish on your own system at only 83 quid delivered still spaces left so get your name on the list
Old 8th September 2011, 05:17 AM
Hoybi's Avatar
Hoybi Hoybi is offline
Hoybi - long range book tub (I suppose it can be sent to Belgium)
Eddy
www.alfaprojects.be
Old 8th September 2011, 12:07 PM
Question
x3 please phil when you can tell me how many ltrs the larger version holds.
Old 8th September 2011, 03:40 PM
Im in for that too Phil---nice one
Please see pm
Adrian
http://s1189.photobucket.com/albums/z429/ayjay50/
Old 8th September 2011, 04:18 PM
That looks quite nifty Phil.
Kinda thinking that the angle on the filler might assist when it comes to fitting the filling stations pump nozel in
Old 14th September 2011, 01:53 PM
rapidtornado's Avatar
Hi Phil, any thoughts of having a tank with swirl pot option for the injection engines?
Thanks
Old 14th September 2011, 05:52 PM
Some sort of sump would be a good idea as in normal fuel tanks where the fuel sender sit's otherwise there may be feed problems even with baffles if the use of oe sender unit is intended.
Swirl pot is a totally different item seperate to tank and involves a low and high pressure pump to feed and return fuel.
