Old 9th September 2011, 09:41 AM
shaun shaun is offline
Default pedals and clutch cable.
Has anybody used the pedals out of the donor, if you have, what colour quadrant did you use for the clutch cable.
My donor had an auto box, so i'm not sure what colour it should be.
Thanks
Shaun
http://www.shaunsroadster.wordpress.com
YOU CAN NEVER HAVE TOO MANY TOOLS!!!!
Old 9th September 2011, 10:40 AM
TSM Locost's Avatar
1. Tiger Avon uses std pedals.
2. mine came with yellow quadrant, but have seen red, no idea what the difference is if any.
3 clutch cable i used with shortened std pedals was Capri 1.3 / 1.6 ohv mk 1 or 2 ( same as sierra but shorter )
Be Lucky, Mike.
Old 12th September 2011, 05:36 PM
my sierra had a yellow one
i still have the peddal box in the garage loft if your after a set
Old 13th September 2011, 04:29 PM
thanks for the replies, Baz I just recieved a set I won on fleabay....thanks for the offer
Shaun
Old 13th September 2011, 04:45 PM
There are two clutch setups from memory, and the parts are not interchangeable. Haynes manual makes reference to the LOW lift components on later models. I imagine the quadrants have differing diameter to suit the normal/low lift clutch parts.
I think I have a red and yellow set ( and possibly a new yellow quad.) But have never paid much attention during swapping and fitting of cables and clutches over the years.
