Old 12th September 2011, 11:15 AM
brainbug007's Avatar
Default Fuel Sender Sealant/Glue?
What sort of sealant/glue would be good use to attach and seal the electrical plug for the fuel sender to a 1mm steel plate?
Old 12th September 2011, 12:19 PM
Been digging and came across zap z-poxy (http://www.axminster.co.uk/zap-z-pox...sin-prod23719/) just wondering if this stuff is ok to use? Is there any difference between this stuff and more generic epoxy's that are alot cheaper? Is there something better to use?
Old 13th September 2011, 09:36 AM
Nobody able to advise on the use of epoxy adhesives with fuel?
Old 13th September 2011, 09:54 AM
Maybe not epoxy based glue as it would be a bugger to remove afterwards. Pro-Seal do a range of Silicone based "Instant Gasket":
http://www.supergluecorp.com/pro-sea...-gasket-makers
Certain colours for differents applications, the black one would be suited to the fuel tank sender. Have used them quite a bit with no issues. Your local motor factors may have them in stock.
AndyH
Old 13th September 2011, 12:03 PM
Thanks spud, so would that stuff also work as an adhesive as I need it to hold it in place as well as seal it?
Old 13th September 2011, 12:53 PM
No i wouldn't use it as an adhesive, self tapping screws would be the choice if you can.
Old 13th September 2011, 01:47 PM
Hmm not sure that will work as its only the small cylinder electrical plug that I need to attach and seal somehow. I currenlty just have a small hole drilled which it sits in but it doesn't exactly stay in the hole that well. Maybe I do just attach it permanently then and if it ever goes or I upgrade my tank I just replace the sender and the small plate I've attached it to?
Old 13th September 2011, 01:57 PM
Sounds the best plan - JB Weld is good for that kind of thing.
Old 13th September 2011, 03:20 PM
Nice one, thanks for your help
