Old 12th September 2011, 06:15 PM
http://www.porsche924-944.nl/manual/.../image002e.gif
Old 12th September 2011, 06:49 PM
Cool
Where there is a will!!. This guy has taken an sfi steel bellhousing and is having it made as a multifit for vw ect to the T5 borg warner.
http://www.motorgeek.com/viewtopic.php?f=15&t=38205
Old 12th September 2011, 08:52 PM
mikequattro mikequattro is offline
thanks for all the ideas and help
Old 12th September 2011, 09:37 PM
I do wonder if that porch torque tube and transaxle could prove to be a winning idea.....
924's are cheaper than chips if out of MOT..
Old 13th September 2011, 10:48 AM
Its great but its basically an audi transaxle with a tube bolted to the front, there would be no where between the seats to get the bell housing in if you try and keep driveshaft centerline right. I suppose you could trim all the bellhousing off and just run a prop to the input shaft.
http://t1.gstatic.com/images?q=tbn:A..._44-_XUQ8sLg1A
bob
Old 13th September 2011, 02:30 PM
Alpha x, Geert in holland had an adapter plate for the type 9 and there is a pic on the forum somewhere.
He is no longer on the forum and has not been for a while.
