Old 21st September 2011, 11:35 PM
Default Finis Codes
I've got a Clutch and cover plate (new old stock) sitting in my garage. I'm struggling to work out what they are off. Finis codes are 6104426 and 6104430. Any ideas what engine these are off?
Old 22nd September 2011, 10:35 AM
Big Vern Big Vern is offline
Microcat doesn't recognise those FINIS codes.
Do you have the Ford part numbers?
BV.
Old 22nd September 2011, 11:05 AM
I sourced some caliper mounts just off the Finis codes, if you go into your local Ford dealer they can use the finis code to find the part.
AndyH
Old 22nd September 2011, 11:18 AM
I have an old luk clutch book and both of those numbers come across as out of one kit which has an luk number of 622 0175 06 1.7 / 2.0 ford consul 1972 to 81 must be the old v4.
Old 22nd September 2011, 11:20 AM
I've had some advice off Locost Builders and it seems the clutch and clutch cover are off a Pinto RS2000 MK 2 Escort. But being Ford, fit a huge variety of other engines (Some Capri's Etc)
Edit: Looking at the Consul, that also had a 2.0L Pinto engine fitted in its later life.
Old 22nd September 2011, 11:43 AM
Talking
That makes sense as they all used the same four speed box in their day.
Old 22nd September 2011, 12:44 PM
AndyH
As above I searched the Ford microcat (what the dealer has) earlier but the FINIS code came up as unknown. Probably older than 1986. I could search by part number/basic number to see what it's compatible with.
BV.
Old 22nd September 2011, 01:18 PM
OK, so I've taken the other numbers off the boxes, but I don't know what they are. Both boxes are marked up Ford Motorcraft.
Clutch plate box has this sticker on it
ECD 134
82GB 7550 AA
6104426
Clutch cover box has this sticker on it
82GB 7563 AA
6104430 ECP 120
Old 22nd September 2011, 05:49 PM
just flicked through the luk book and that plate and cover combo are used in 1.6 cortina up 71 on, rs2000 and capri 2.0 71 on , the kit number changes because of the thrust bearing.clutch plate should be 215mm dia with 26mmx23 spline.
