Old 6th October 2011, 07:19 PM
james3004's Avatar
Default Fuel Pump / Injectors
I having trouble getting my head around this but....
Am I right in thinking that this Pump:
http://www.ebay.co.uk/itm/4002464231... 4.m1438.l2649
Will be ok for these Injectors:
http://www.ebay.co.uk/itm/1707063038... 4.m1433.l2649
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 6th October 2011, 07:27 PM
May be a good idea if you explain what you intend to do with them and why and maybe someone will point you in the right direction.
big_wasa's Avatar
big_wasa big_wasa is offline
yep sure will
Nowt again.
Old 6th October 2011, 07:29 PM
james3004's Avatar
They are going in my 1800 ZVH Turbo running Megasquirt
All this litres per hour a bar stuff confuses me muchly
--- James ---
Flickr Album
Old 6th October 2011, 07:48 PM
there is some universal pumps on the bay that should be fine for most kitcars using eletronic injection as most systems regulate at 3bar
http://www.ebay.co.uk/itm/Electric-3bar-petrol-fuel-pump-kitcar-project-hotrod-/280749628880?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item415dfb5dd0
Old 6th October 2011, 08:05 PM
james3004's Avatar
In Theory this one would fit?
http://www.ebay.co.uk/itm/FORD-ESCOR...item519b36c38a
--- James ---
Flickr Album
Old 6th October 2011, 10:08 PM
Originally Posted by james3004 View Post
that looks like a bosch mechanical type fuel injection pump im not sure thay are the same kind of thing as its a diffrent kind of system (mainly fitted to 80s cars)
it may work but could effect its lifespan
Old 7th October 2011, 08:27 PM
rich's Avatar
rich rich is offline
same as mk1 golf bosch fuel pump, got mine from gsf car parts, think it was around £30 odd + vat, bit cheaper than ebay, same pump.
The pump will run any modern fuel injection system no problem, non standard engine management and injectors will be better with a adjustable fuel pressure regulator
