Old 5th October 2011, 01:19 PM
james3004's Avatar
Default Steering Column extension
Does anyone have a spare bit of thick wall 15mm ID tube I can have/buy to extend my rally designs shaft?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 5th October 2011, 08:29 PM
davylock davylock is offline
I will have a look in the Garage tomorrow am, I should have a length left over long enough. I got about a metre or so from a Hydraulic Engineering Business I wasn't prepared to pay 75p + VAT an inch + delivery !!!!!.
I'll PM you the length and OD + ID, if you are still looking, Dave.
Old 5th October 2011, 10:33 PM
james3004's Avatar
That would be great thanks, I'm not sure what length I need but the shaft is around 400 I think, maybe someone will know off of the top of their head?
--- James ---
Flickr Album
Old 6th October 2011, 01:31 PM
Default found it!
James,
After raking around in the garage, I found a 53.5cm length of seamless tubing It has an 20.12mm outside diameter, 14.6mm inside diameter and wall thickness of 2.71mm approx ( measured with my cheapo digital calipers! )
It is the other bit left of the one metre length I bought, slightly longer than the bit I've used.
I slightly skimmed the smooth ends of the splined shaft so that the ends slid in nice and tight, although they would paper down with a bit of effort.
Let me know if you are interested, Dave.
Old 8th October 2011, 01:21 PM
rdodger rdodger is offline
If James doesn't take it off you then I would be interested
Old 8th October 2011, 05:00 PM
Sorry RDodger, It's on it's way to James, but if your struggling try a Hydraulic engineering shop, they tend to use it more than general fabricators, Dave.
