Old 10th October 2011, 01:16 PM
brainbug007's Avatar
Default Strapping Coolant Hoses To The Chassis?
Whats a good way to strap the coolant hoses to the chassis? I'm thinking something like long cable ties would do the job but will they stand up to the heat and not melt?
Old 10th October 2011, 01:54 PM
I made mounting points on my chassis and fitted U clamps onto them to hold the hose in place (mine run quite close to the exhaust so can't afford for them to wobble about) Zip ties aren't going to melt, but I don't like them.
Old 10th October 2011, 03:27 PM
zip tie will cut into the pipe over time too.
Old 10th October 2011, 04:14 PM
You can get metal 'P' clips with rubber linings that you could use to attached pipes to the chassis using rivnuts.
