Old 4th December 2011, 03:04 PM
Default Transit Tie Rod/ Drag Link
Hey guys,
Found this in a pile of stuff that may be of some use to someone.
Its a Transit tie rod/drag link off a Ford Transit 1985-1992 Tie Rod End,
The Quintinn Hazel number is QR 2392S,
LH thread, Cone Size: 16,2 mm, Outer Thread [mm]: M20X1,5
Not sure if this is the one required for the roadster?
Old 4th December 2011, 04:27 PM
I believe the roadster uses right-handed versions on both ends.
Old 4th December 2011, 04:34 PM
TSM Locost's Avatar
-- Transit 1965 to 84 Drag Link End Right Hand Thread
Ford Part Number :17996516
QH (Quinton Hazel) Part Number QD1117RHT
M18 x 1.5 not M20 x 1.5
Be Lucky, Mike.
Old 5th December 2011, 02:02 PM
Ricky Ricky is offline
Red face maxi ball joints
Hi everyone I wanted to know if someone could help me I'm in south africa and its very hard to find a austin maxi ball joint and cause I have no dimensions of it so I was told on this forum that I should take a look at the mini cooper lower ball joints and the dimensions look the same only thing though is that I won't use a 19 mm taperd reamer ill have to use a smaller one so I wanted to find out if that will be ok to use as an alternative or does anyone have a better idea .thanks
Old 5th December 2011, 09:51 PM
Default ball joint
I'm not sure about the sierra hubs but i'm using scorpio hubs and a 16 mm non tapered ball joint from a peugeot 306 that just bolts in like the original.
As i say, i don't know if this helps but her is the link to the ball joints i fitted.
http://www.ebay.co.uk/itm/GENUINE-PE...-/320636614293
