Old 20th December 2011, 09:33 AM
brainbug007's Avatar
Default Wishbone adjuster nuts
Am I right in thinking that the camber adjuster on the wishbones at the back need to have a locking nut of some kind for iva? If so can anyone advise what size it is (I think its something like M18?) and not having the car or book infront of me at work, I can't remember if there's something similar at the front so I'd need 4 nuts in total? I'd like to find em on ebay today to get them before the weekend to fit them while I've got the wheels off to fit my body panels
Old 20th December 2011, 09:37 AM
It's not needed at the rear as it can't rotate.
Old 20th December 2011, 10:04 AM
If you do put them on the rear they will stop any small movement of the adjuster against the threads in the wishbone. Might lead to a knocking on the as the threads loosen up.
Rear - M20 x 2.5
Front - M18 x 1.5
Half buts are better.
AndyH
Old 20th December 2011, 11:01 AM
Ok well I think I'll put them on just to be on the safe side. Will these do the trick from a stainless grade point of view and the right type that you're refering to?
http://www.ebay.co.uk/itm/M20-HALF-N...item19cbbe85d7
http://www.ebay.co.uk/itm/M18-x-1-5-...item2308899ac5
Old 20th December 2011, 11:06 AM
They are fine Brian even though the M18 are expensive.
AndyH
Old 20th December 2011, 11:07 AM
Tell me about it, know anywhere else to pick a couple up a bit cheaper?
Old 20th December 2011, 12:34 PM
We usually get them supplied with the drag links. Get them from Rally Designs but buy in bulk for a bit of discount. You can buy them each for £6.50 + Vat or give them a ring and they might sell you a pair of half nuts on their own.
AndyH
Old 20th December 2011, 03:04 PM
Do you know if they're right handed? Came across these which are a bit more reasonable?
https://www.tyagiracing.com/products...-Lock-Nut.html
Old 20th December 2011, 03:38 PM
They look more reasonable Bryan, yes they are right hand threads
Old 20th December 2011, 05:20 PM
A pack of 5 M18 X1.5 half nuts can be had a tad cheaper here.
M18 half nuts
You could always share the cost with another builder
Did have some spare ones here but have passed them on to other builders on the forum
