Old 7th January 2012, 09:51 PM
stew stew is offline
Default Anti - corrosion for internal of RHS chassis members?
Whats the general consensus?
I was thinking either injecting something like waxoyl into the chassis once finished.
Or expanding foam?
Or is it worth bothering?
I was thinking to avoid any rattles etc from inside the chassis.
What do the likes of caterham/westfield etc do?
Im maybe overthinking, but its a sat night and im stuck in! lol
cheers,
Stew
Old 8th January 2012, 12:55 AM
I dont think expanding foam will do anything.
Try something like this;
http://www.supercheapauto.com.au/onl...56#Description
Old 8th January 2012, 11:04 AM
Andy_B Andy_B is offline
I doubt if there is anything rattling about in the RHS you will be able to hear it anyway ...pretty loud these cars
Old 8th January 2012, 01:20 PM
Been mentioned before and opinion is that there is very little rust on the inside of the welded tubes as there is no ingress of moisture,a squirt of waxoil or wd40 would not go a miss in the open ends.
Old 26th January 2012, 03:34 AM
Toyotus Toyotus is offline
Just saw this in my hotrod magazine!
http://www.facebook.com/photo.php?fb...7&l=f7d01629af
Old 27th January 2012, 06:52 PM
there was this stuff called ziebart
seen it on an old mk1 fiesta and a alfasud both spotless in the rust deparment
was like a black waxoil not sure if you can still get it but cars i have seen spoke for themselfs
alfasuds where known for rusting
im going for some form of wax injection on mine
Old 27th January 2012, 09:02 PM
Deanno's Avatar
Deanno Deanno is offline
They all look like good ideas but the only way you can be sertain you cover everthing is by galvanising?
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 27th January 2012, 10:05 PM
Think you will find Ziebart died along with plugs,points and condensers,used to use it on new cars in the 70's.
Old 27th January 2012, 10:16 PM
Filled the box section chassis of my Land Rover with old engine oil----seemed like good idea til it needed some welding
Old 28th January 2012, 01:27 AM
if was good enough to keep the rust buckets from the 70s alive to the 00s even things like fords and alfas that would keep there owners awake at night as thay could hear them rusting apart it must have been good.
most of them cars can only be swept off a workshop floor now
