Old 16th January 2012, 05:44 PM
Question Relays
I need to use some of the relays from my old donor fuse box(ford 1.8 cvh) but cant see any indication which does what.
Anyone know what colour or number does what please?
I need the main beam , dip beam and fog light please
Old 16th January 2012, 06:13 PM
Did you look on the back of the fusebox lid, as the diagrams are usally moulded onto it?
Old 16th January 2012, 06:34 PM
Did that!
It just shows the relay position with a Roman numeral - the fuses are identified on a label, perhaps my relay label disappeared over its 25+ years
Anyone still got a cvh fuse box lid.
BTW got my loom from PWS(Premier) ----I could be on a roll,it comes with INSTRUCTIONS
Old 16th January 2012, 07:54 PM
Is it the same as this?
http://www.2carpros.com/forum/automo...fuse_box_1.jpg
Old 16th January 2012, 08:49 PM
No
All the fuses are aligned on one side( but thanks for trying)
Old 16th January 2012, 08:58 PM
Luke2842's Avatar
Luke2842 Luke2842 is offline
I found out for my dohc in the Haynes manual, says relays and roman numerals.
Old 16th January 2012, 09:35 PM
Got the Haynes manual and searched for the info .Ill look again
Old 16th January 2012, 09:50 PM
Give me a reg year and a list of the relays you want and I will look at the official diagram
Old 16th January 2012, 10:14 PM
H871GLK --- 1990
(thought it was older than that)
Main beam ,dip beam and foglight
Old 16th January 2012, 10:32 PM
Luke2842's Avatar
It's in with all the wiring diagrams
