Old 22nd January 2012, 09:47 PM
Ashtonr Ashtonr is offline
Default Bigger engine and DVLA
Does anyone know what you need to do if you change the engine after the cars registerred, is it simply inform the dvla of the new engine number and size or do you need another inspection of some description ?
Old 26th January 2012, 04:23 PM
If it is done after the car has been IVA'd and registered it should just be a case of notifying the DVLA of a change of engine number and capacity as with any other car.
If you have not yet put the car through IVA though it may be worth changing the engine details on the donor vehicle's V5 before going through the IVA process. If you do this take a picture of the engine in the donor just in case it is asked for at IVA to prove that engine really was in the donor car.
Old 26th January 2012, 05:39 PM
This is a lot more of a pain than it used to be, the DVLA wants prrof of the engine's origin! or at the least an inspection of the engine number and casting code.
Old 29th February 2012, 09:43 PM
gus's Avatar
gus gus is offline
Hi, today i recived my new V5 after changing the engine.
I sent them 2 photos of old engine [1 in the car and 1 of it out ] ,1 of the new engine in. Also a letter from Ford to confirm the age and CC.
Gus
