Old 5th February 2012, 09:52 PM
Nice to see the build pictures coming along.
Did you take any measurements or did you draw a diagram when you made the engine mounts? I am using a 1.6 myself and want to get around the bonet clearance problems.
If so please can I have the details
Old 6th February 2012, 05:35 AM
Haha, it does look a bit "Solo Polo Peeper" now you mention it Michael
Johno - that rear wheel is only on there very loosely at the moment, which might be why it's sat at that angle.
I'll try to remember to investigate and take some measurements next time I'm out there.
David, if you look through my photos there should be a load with measurements showing my intended engine position.
Essentially I've just got the sump 40mm below the bottom rail, and the engine offset to the passenger side by 25mm.
I've also purchased an inlet manifold from a Mk2 1.6 recently, which may or may not help with bonnet clearance - watch this space!
Old 7th February 2012, 01:17 PM
My lovely shiny protechs arrived from NTS today
Old 8th February 2012, 09:29 PM
I'm now officially rolling
Couldn't resist getting in and going for an imaginary drive!
Old 11th February 2012, 03:20 PM
Looking great
Nice to see that chassis on wheels
Did you make "brum brum" noises ? we,ve all done it , well maybe under our breath
Old 11th February 2012, 04:23 PM
I certainly did!
Though to be honest it was a bit more "crazy frog" than "brum brum"
Cheers Andy, I have to say it was great feeling getting it on it's wheels, I couldn't stop grinning for a while
Old 13th February 2012, 11:20 AM
Got my Battery today. A dinky little Odyssey PC680, which should fit nicely in the passenger footwell without taking up too much leg room (not that I particularly care about passenger legroom!)
Old 13th February 2012, 12:02 PM
mark mark is offline
Fitted the same to my car last year when I upgraded and its spot on
Reasonably powerful for its size too
Mine came off the road at the end of September and the battery has been disconnected whilst Ive been tinkering, just got it all back together a couple of weeks ago and the battery cranked it over perfectly, as if it had just been charged that day!
Old 13th February 2012, 01:55 PM
Hi Mark, that's good to know thanks!
I've got an optimate kicking around somewhere which I plan to use to keep it in tip top condition. The chances of me actually remembering to use it are pretty slim though
Old 13th February 2012, 03:13 PM
james3004's Avatar
Where did you get the battery from john, that's what I've been looking at for my build
--- James ---
IVA passed 20 June 2017
Flickr Album
