Old 7th March 2012, 11:47 PM
degmwilliams degmwilliams is offline
Default Do I need imrc unit when fitting throttle bodies?
Iv got a focus st170 for my engine, I'm going to fitt motor bike bodies and fit another aftermarket ecu. Can I get rid of the imrc unit?
Old 8th March 2012, 03:37 PM
I would speak to the intended supplier of the aftermarket ecu and see what they recommend.
Old 8th March 2012, 05:24 PM
Whats IMRC?????
Old 8th March 2012, 07:04 PM
It's the inlet manifold runner control unit.
Old 8th March 2012, 09:55 PM
Im running megasquirt on a vauxhall engine and ive binned pretty much everything :-) bike bodies now fitted but nothings run yet !
No help i know but inlet manifold runner control unit ? If it does what the name implies that it controls air flow in the runners and your getting rid of the runners and the ecu that requires the input from said unit id say you wont need if but i dont know the ford engine or the ecu u plan to use ?
