Old 27th March 2012, 06:31 PM
MarkB MarkB is offline
Geometry is everything with a car like a 7, get it wrong and you have a pig.
Old 27th March 2012, 08:29 PM
BackyardRacing BackyardRacing is offline
so are the mx5 uprights etc better than the sierras? i.e not having to use mushrooms etc. is the geometry any better?
also is there any weight differance between pinto setup and the mx5 setup?
lastly, i really dont want a bonnet scoop/bulge, will the mx5 motor fit under standard bodywork?
cheers again, sorry to pester
Old 27th March 2012, 08:47 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
The mx5 does not use the mushroom adapters
Dont know about the weight difference
The bonnet will need a bulge to clear the plenum on the mx5 engine
Old 28th March 2012, 10:23 PM
With a change of airfilter/ airbox the MX5 motor will sit under the Roadster bonnet. It also gets away without needing to modify the sump and oil pickup.
