Old 3rd April 2012, 09:42 AM
misty misty is offline
Default R! bike carbs question
Hi all
I am using r1 bike carbs with the r1 fuel pump BUT what do i do with the pinto fuel pump di i block it off and if so how would the best way to do that
Old 3rd April 2012, 10:13 PM
tkpm tkpm is offline
Get one of these, thats what i've done.
http://www.ebay.co.uk/itm/FORD-PINTO...item2c6406941a
Terry
Old 4th April 2012, 07:41 AM
many thanks 1 on its way now should i put a gasket on it as well
Old 4th April 2012, 07:43 AM
snapper snapper is offline
A standard fuel pump gasket, yes
There is a little drive pin actuated by a cam on the auxiliary shaft, remove that after removing the fuel pump and before putting the blanking plate on
