hey hey,
I think i may have an issue , i need to take a look at the iva manual but what do you chaps think. basically i think i may have mounted my seats to low to mount my harness on my roll bar ? ![]() ![]() if this is too low, do you reckon i could weld a hefty device to go between the upper cockpit chassis rails sb summat summat and the other sb summat Ta! |
Rather than using the harness holes, just take the harnesses around the outside of the seats. The seats would no longer become structural in the event of a crash.
Gets you around the IVA implications. Check the manual for minimum heights ect. ![]() |
cheers steve , i completly forgot that you can run them on the outer. im off out to go measure the ref point etc.. just been reading the iva bible
wish me luck! mike p.s you must have uploaded that at the time i was reading it :P |
I think I am in the ok,
![]() you can just see the rulker pretruding here "through the seat holes" which is good ![]() ![]() and this is all mesured at 450mm minimum from ref point |
