Old 5th May 2012, 08:21 PM
tkpm tkpm is offline
Default Welding the sump (Pinto)
As i'm unable to go to Stoneleigh tomorrow,
I though i would have a go at cutting and welding my sump tomorrow morning, been putting it off up till know. The last time i tried welding steel that thin, all i seemed to do was blow hole through the thin steel. So any tips peeps can give will be appreciated.
Terry
Old 5th May 2012, 09:18 PM
What method are you using to weld it you dont say, the bigest thing to remember is clean away any traces of oil and paint it needs to be spotlessly clean. And the other thing i would say is take your time and dont get too carried away, getting too much heat, weld in small sections
good luck
Old 5th May 2012, 10:29 PM
SeriesLandy's Avatar
Best way I found was "spot" welding it, lots of single triger pulls, bit like this:
Old 5th May 2012, 11:52 PM
Thanks guys,
Terry
Old 6th May 2012, 12:09 AM
mgglep's Avatar
mgglep mgglep is offline
If you can TIG is best as it is no porous like MIG
My Build pics
Old 6th May 2012, 12:11 AM
mgglep's Avatar
Sorry I mean TIG is non porous unlike MIG
My Build pics
Old 6th May 2012, 12:20 AM
misty misty is offline
if you can get a piece of copper clamp it on to the part your going weld
Old 6th May 2012, 01:27 AM
Misty your going to have to run that one by me again.
I have to use a mig as thats all i've got, unless someone can recommend one.
Terry
Old 6th May 2012, 02:33 AM
PorkChop PorkChop is offline
Terry
Use the copper as a heatsink to take out excess heat from the join
Old 7th May 2012, 02:46 PM
if you get stuck terry give me a ring i could tig it for you.
try and use .6 wire if you have any and run as low as you can go on power
work in small sections 1/2 inch or so mooving around to diffrent ares so nothing gets too hot
