Old 13th May 2012, 08:32 AM
Default Thread sizes..
I need to order some nuts to temporarily fix my bottom ball joint and track rod ends.
Any Ideas what the thread size is for these..
Old 13th May 2012, 09:38 AM
Wynand's Avatar
Wynand Wynand is offline
Im using the Transit ball joint and Escort mk2 rack and just measured the rack end thread; M14 (diameter) x 2.0mm (thread.)
Hope this helps
Wynand
http://5psi.net
Old 13th May 2012, 09:43 AM
I presume you are talking about the nylocs or castle nuts that hold the track rods and the ball joints IN TO the bottom of the upright and the mushroom? I have a thread gauge and zeus book at the shop I'll check later, the tapers will be the same as the OE parts obviously how ever I can't say the same for the threads.
Old 13th May 2012, 10:17 AM
Steering rack M14 x 2mm
Transit drag link M18 x 1.5mm and M12 x 1.5mm
Maxi balljoint M12 x 1.25
Old 13th May 2012, 04:15 PM
do what i do just add a stack of washers to stop the nylon ring touching simples
