Old 15th May 2012, 05:23 PM
Here is another version. Kin cheap as well http://www.burgertuning.com/paddleshift.html it would be worth just using a later auto box to make it all work.It would be the nuts.
Old 21st June 2012, 11:51 PM
I've looked into this a little bit more and it seems its not a very hard upgrade to marry a E39 Steptronic to the M60, then its just a case of finding a paddle/button equipped steering wheel setup which again can fairly easily be mated up.
I've not looked at all the details yet but there does seem to be a few that have done it.
I've a long way to go yet before I get to this stage though but still thinking about it
Old 22nd June 2012, 12:13 PM
This auto thing is a ++ situation because you wont need a clutch pedal you can stretch the gear tunnel width at the front and shove the engine right back.
