Old 27th June 2012, 07:28 PM
will_08 will_08 is offline
Default Front shock bracket mounting?
Is there any trick to mounting these 2?
Or is it just careful measurement?
Cheers Will
Old 27th June 2012, 09:23 PM
trick-kit trick-kit is offline
Do you have the wishbones made? If so the easiest way is to assemble the parts use either the shocks or some dummy bars and put the shock bracket on the end of them and lift the wishbone up till the bracket hits the chassis.
TK
Innovation not Imitation!
Old 30th June 2012, 08:11 PM
Yeah ive the wishbones but no, poly's. ill need to wait till ive got them i guess.
Thanks for the tip
Old 1st July 2012, 11:21 AM
mmm... Can anyone tell me if these top suspension brackets look ok? From the book the centre of the bracket is 83.5mm from the front jig thats what it is but i thought it would sit more on the tube!
Cheers Will
Old 1st July 2012, 12:06 PM
Tatey's Avatar
Tatey Tatey is offline
That's definitely different to how mine is, mine sits more over the chassis tube, mine looks how it looks in the book.
Old 1st July 2012, 12:47 PM
aye thats what i thought. but why?!?!?!?!?
this is the 3rd front frame now, and its been made by a pro!
Old 1st July 2012, 01:24 PM
Definately looks wrong.Had a similar problem myself.When u set the jig up to position the bracket you need to make sure the jig is square and upright.Looks to me like you need to check your jig is upright.
Old 1st July 2012, 04:19 PM
i had a set square at the base, unless its warped somehow. both suspension brackets are identical though.
Driving me crazy this!!!
Old 1st July 2012, 05:27 PM
I din't think it is that far off the mark....here is mine
http://www.haynes.co.uk/forums/showt...t=4493&page=18
Old 1st July 2012, 05:55 PM
PorkChop PorkChop is offline
Are BR1 and BR2 meeting the front frame squarely? There seems to be a rather large gap in your photo.
