Old 9th July 2012, 07:51 PM
Default IVA Checklist
IVA Queries
Rear Registration Plate
2) The space must permit the mounting of a plate in a position as close to vertical as possible taking into account the shape of the bodywork.
Does anyone know if the angle of the rear tub is acceptable to pass the IVA, or will a wedge be required to make the number plate nearer to vertical?
Also, does anyone have any key points I should be checking?
Plastic Nut / Bolt Covers - Tick
GRP Cycle Wing Trim - Tick
Cycle Wing Stay Brackets - Tick
Bonnet Edge Trim - Tick
Aeroscreen Trim - Tick (Does the lower return require trim as well)
Rear Tub Trim - Tick
Inner Edges of Scuttle Return - Tick
Inner Edge of Nosecone - Tick
Steering rack / Top Wishbone Ball Joint Nuts - Tick
Steering Rack Extension Rubber Gland Cover - Tick
Flexi Brake Hose onto front caliper - Tick
Trim to underside of Headlight Mounts - Tick
Fog Light Vertical - Tick
Exhaust Silencer - Tick
Correct E Marking on Lights UPDATE (Ozzy1)
Seatbelt Boss Gusset UPDATE (Deezee)
Thread sticking out of nylocs UPDATE (Deezee)
Roll bar main bolts need to have strength rating on them UPDATE (Deezee)
Any help appreciated to make sure its all covered.
Old 9th July 2012, 08:15 PM
SeriesLandy's Avatar
Per iva pics would be a good idea. Much easier to spot anything glaringly obvious.
Old 9th July 2012, 08:54 PM
Loads of photos of the flicker Hyperlink N06
Also, the IVA manual states that fuel filler caps cannot be in a luggage compartment, so is the rear tub a considered as a luggage compartment? Will I require an external filler pipe?
Old 9th July 2012, 09:26 PM
Are we close to another car on the road then
Old 9th July 2012, 10:43 PM
PorkChop PorkChop is offline
I haven't heard of anyone needing a plinth for the rear number plate. The MEV Exocet has an angled rear plate area too and I haven't heard of anyone needing a plinth for that either.
I would imagine that if you don't have a boot floor, then you wouldn't have a luggage compartment.
Old 10th July 2012, 01:31 AM
If u dont have a lid on it or a bottom it can't be a luggage compartment.Also u wouldn't have a rear number plate fitted for IVA as u need the Iva to get a number plate?
Old 10th July 2012, 01:35 AM
Only one I can think of is do all of your lights have the correct 'e' markings on them.There was a link I think in the announcements section I think with this info.
Old 10th July 2012, 01:00 PM
Its hard to tell as I'm not sure how up to date the Flickr photos are. For me I picked up on.
- Rear roll bar braces only have 1 bolt - (ashg IVA Failure)
- Roll bar main bolts need to have strength rating on them, or supporting paperwork.
- Thread sticking out of nylocs. They'll even ask you to take off your rubber nut covers to ensure the nylocs have enough thread going through them.
- Edge projection applies to all edges, so you'll fail if you don't cover the rear seatbelt gussets on the roll bar.
- You've covered your fuel pipe coming from the tank, will they be able to read the writing on it, for its suitability for use with petrol?
Old 10th July 2012, 10:04 PM
if its in a inclosed area the iva man will not like the look of it so leave the cover off
if its open at the bottom area of your tub you might get away with it.
i think its all about fuel vapor in enclosed spaces
Old 11th July 2012, 12:10 PM
Just going through the notes and checks I made for my IVA and thought of the following.
- 19mm radius on the bottom of the dashboard
- Secondary fixing for the upright mushrooms
- Correct radius where aluminium panels meet the chassis local to seats (on the curved section)
- Can your, or your passengers knees / legs touch anything under the scuttle? I had to box it in on the passenger side.
