Old 11th July 2012, 11:44 PM
BenBrooks BenBrooks is offline
Default Painting
Hi all probably a basic question so bear with me. In terms of painting wishbones and the chassis what's the best course to take? my dad was saying an epoxy primer and then a metal paint but googling it all there are so many types with so many different product numbers etc that i have no idea what they are!
so to cut to the chase. how many coats what primer and what top coat?
this is for chassis and wishbones and running gear i.e. painting the diff etc
cheers guys!
Old 11th July 2012, 11:52 PM
PorkChop PorkChop is offline
I plan on using epoxy mastic paint for the chassis. I've used it on other cars with good results. Ash G painted his chassis with epoxy mastic as well IIRC.
Old 11th July 2012, 11:55 PM
just did a quick google and it looks like it could do the job. is that all it needs then?
Old 12th July 2012, 12:09 AM
That's all I've used on my other cars, although I usually use a underseal type product afterwards to match with the original factory finish rather than have patches of different paints.
With sufficient layers it should be solid enough - this is the stuff I've used - http://www.rust.co.uk/epoxy-mastic.cfm
HTH
Old 12th July 2012, 12:17 AM
yeah that's the website I found.
cheers for your help
Ben
Old 12th July 2012, 12:16 PM
Coozer's Avatar
Coozer Coozer is offline
Is it OK to use epoxy mastic over red oxide? As the welding has progressed I have slapped red oxide over it to keep the rust at bay... need a top finish now.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 12th July 2012, 03:09 PM
A good acid etch primer will keep rust at bay even unpainted as I am finding out now as the rolling chassis is out in all weathers getting pushed in and out of the garage every day.
