Old 10th August 2009, 12:52 AM
Raceral....
i like the "sunken" handbrake lever
& is that a brake bias valve behind the handbrake lever?
Old 10th August 2009, 03:14 AM
raceral raceral is offline
Thanks HandyAndy, the handbrake is off a Honda Civic I found in a wrecking yard.
And you are also correct on the adjustable bias valve.
Al
1969 Amx
2004 Passat 1.8T 5Spd 4Motion
Haynes Modified Super 7 3.4L V6
www.lotussuper7replica.com/
Old 10th August 2009, 05:33 PM
That Pinto pic threw me as well,I remember taking it of the drivers side inner wing and the carbs on the other side.
Old 10th August 2012, 10:06 AM
jps jps is offline
Old thread I know - but it's where I am now!!!
Looks like most people just drill into the chassis rails (and rivnut?) to secure their p clips?
Does the 'perforated strip' idea mentioned in The Book mean "welding on a strip of 1mm plate that you've drilled a load of holes in" - like the pic in Dogwoods post (page 1 of this thread). And do most people not bother with this approach?
Just want to make sure I weld everything necessary before painting!!!
Old 10th August 2012, 01:15 PM
gus's Avatar
gus gus is offline
I used 40 x 3 , drilled every 100mm with 3mm holes for pop rivet's ,top and bottom of tunnel.
Old 10th August 2012, 02:52 PM
jps jps is offline
Originally Posted by gus View Post
40 x 3
What is 40 x 3?!
Old 10th August 2012, 03:58 PM
40mm wide x 3mm thick flat steel strip.
Old 11th August 2012, 11:17 AM
You can also paint your chassis, and fit the strip afterwards with rivets, as Simon (Tatey) did:
http://i292.photobucket.com/albums/m...e/DSC02115.jpg
Old 8th October 2012, 08:30 AM
jps jps is offline
Cut some 3mm x 25mm strip this weekend ready to weld in the tunnel - couple of pics on my blog (link in footer)...
