Old 4th September 2012, 08:18 AM
How many for sure and how many maybe in the futures?????????
Old 4th September 2012, 01:05 PM
Will this set fit LHD racks?
Old 4th September 2012, 09:04 PM
Originally Posted by robo View Post
Right then chaps, the rack and pinion made to the right length -27mm is £110 but you will still need to buy an old escort rack and two new gaitors so you can use the housing. A few different ratios available as well 2.2,2.4,2.9 Fitting is easy. The extended arms < exact length to be decided cos I am confused > are £25 each. all this is suject to making up an order for 10 minimum. He never mentioned the vat so I will check to see if its inclusive. £160 + some gaitors is not bad.
Thoughts and comments please.
Seems quite expensive.
Old 4th September 2012, 11:27 PM
Is it that bad when you take off the price of the rack extensions Alga I will pop the question on the left hand drive one, what ratio do you want?
Old 5th September 2012, 02:15 AM
Rob,
I'm trying to get in my head exactly what you get with this kit. My car is already OTR using a 2.4. Im trying to work out wether its worth the expense to get the correct geomatry or not ? I don't think the car has noticeable bump steer but i may be be wrong
Old 5th September 2012, 10:53 AM
The last car I built was sent away for the full monty suspension set up. The difference to drive was night and day., and I thought it was good before it went in. So I will go for it and do like johno has done and make all four corners adjustable, get the rack right and be a happy bunny.
Old 5th September 2012, 11:50 AM
Something quick, 2.1 or 2.4... Although I'm not certain I'll participate, I've paid ~150 pounds for the RallyDesign LHD quickrack already...
Old 5th September 2012, 08:29 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I could still be interested if they are the right length and threads for the mx5 track rod ends
Old 5th September 2012, 10:59 PM
I'l be in the maybe bracket, need to figure out the chassis first
