Old 9th September 2012, 06:15 PM
jps jps is offline
Default Engine position
How does this look? I'm getting everything in place so I can get the engine and gearbox mounts in place. Sitting at the wheel the gear lever is perfect but I am a bit concerned that there seems to be LOADS of room at the front end, so i'm wondering if i've got it too far back.....?
There is roughly 2cm between the back of the block and the rail that goes across the top of the footwells...
http://www.facebook.com/photo.php?fb...type=1&theater
Sorry - haven't cracked uploading photos into posts yet...
Last edited by jps : 9th September 2012 at 07:02 PM. Reason: Edit - worked out how to embed photos!!!
Old 9th September 2012, 06:33 PM
SteveMX5 SteveMX5 is offline
Spot on I reckon, further back you can get the engine the better IMO
Old 9th September 2012, 06:45 PM
you can never have it too far back unless it is behind you.
Old 9th September 2012, 08:05 PM
Well said that man,be aware of the clutch arm hitting the panel near the foot well.
