Old 20th August 2012, 09:25 PM
jps jps is offline
Originally Posted by MikeB View Post
Here are the dimensions for the AGM bodywork
AGM haynes diminesions by mjb22001, on Flickr
Perhaps i've missed something - but the scuttle is 1135 wide, and is 'a butt fitting and doesn't overlap'... How does that work when the chassis in the book is 1118 wide?
Old 20th August 2012, 09:37 PM
Side panels add 17mm?
Old 20th August 2012, 09:57 PM
jps jps is offline
Ah - i'd assumed 'do not overlap' meant - doesn't overlap the top chassis rails. Perhaps it means the bonnet doesn't overlap the scuttle, or nosecone at either end...
Old 21st August 2012, 11:11 AM
MikeB MikeB is offline
that right the nose bonnet and scuttle don't overlap, I'll get some pictures up when I pick up my body work next week
Old 31st August 2012, 09:19 PM
Hi Mike,
Have you got your bodywork yet? If so whats it like...
Old 2nd September 2012, 10:09 AM
hopefully this friday
Old 10th September 2012, 12:00 PM
Picked up my bodywork on Friday from Barnsley
Having seen a fair amount of Fibreglass work previously I'm happy to say the quality is definately there, I get the impression Alan knows his Fibreglass.
I couldn't find a single mark or blemish on it.
Just having it plonked on top of the chassis doesn't do it justice so I'll post some pictures once I have at least the nose bonnet and scuttle properly lined up! (note couldn't resist so theres a couple in my build thread)
The bonnet/nose scuttle, lines up nearlly perfectly with really tight lines due to how they are made, the bonnet will keep its shape due to the returns on the front and back edge. My CVH fits snugly under it with a cm or so gap, and don't forget this kit has a lower line look which is what I was after,
The only area for improvement would be the side panels extending to full length and getting a sharper line where they have to come in round the side of the chassis.
Old 10th September 2012, 02:33 PM
rapidtornado's Avatar
Thanks for the update Mike, keen to see the pics... think I'll be going with AGM as the reports thus far are v.good.
Rapid
Old 10th September 2012, 02:45 PM
they are on my build thread click on the link below
Old 10th September 2012, 07:48 PM
DRCorsa DRCorsa is offline
Mike, congratulations for the buy!
Would it be possible to post here the prices of each of the parts?
I have read somewhere that AGM is quite cheaper than either equinox or Saturn, but how much?
Thanks!
