Old 1st October 2012, 09:21 AM
rapidtornado's Avatar
Default Do I need this/these?
gents
A little quiz to start the week
Thought I'd have a go at stripping the donor loom out and seeing if I can get it to work, not that confident but if all else fails I'll get one from Premier but thought it's worth a go ... in the spirit of building your own car and all that.
OK loom is from a 92' DOHC 2.0i
I think this htread may have more questions to come but here's the first few parts that need identification, from what I can see is part of the ABS circuit/loom?
same loom, different connectors
and again same loom, this is the end of the loom
Thanks in advance for your help
Rapid
Old 1st October 2012, 10:11 AM
Relay Identification:
This is the last relay in the rack that housed the ABS relays (x3) and I think the heated windows etc?
Anyway this is the last one left and I cannot identify it by tracing back the wires. There are green/black, red, black and brown wires coming from it and the green/black has about 3" wire then goes straight to a 30A fuse (almost attached to the relay rack) you can't see it in the picture but it's right next to the relay.... any ideas?
Relay details also on 1st pic if that helps
Old 1st October 2012, 12:31 PM
SeriesLandy's Avatar
I can do one, the last pic (first post), black connector (red insert) goes to the dizzy. No idea about the rest
Old 1st October 2012, 07:46 PM
The middle pic with the two plugs looks very much like the diagnostics plugs on the Mondeo loom. The triangular one is the looks like the STAR connector you can use to read the error codes with. One of the wires is ground, the other is self-test-in, the other one is self-test-out. Ground the STI, connect a LED to STO and count blinks.
Old 1st October 2012, 08:05 PM
the first few pics are of the ABS loom as you guessed.
It just unplugs from the main loom.
Don't chuck it though, may be useful to a sierra owner.
Old 1st October 2012, 09:24 PM
Thanks guys, much appreciated. You guys are like walking circuit diagrams.... that explain things
I'm sure there's more to come
Thanks
Rapid
Old 1st October 2012, 10:32 PM
TT, any ideas on the relay?
Rapid
Old 1st October 2012, 11:33 PM
Ben_Copeland's Avatar
Googled the part number 78eg 11406 CA
Shows as one of the Fuel Pump Relays ? Does that sound right
Also found cooling fan relay?
Old 2nd October 2012, 01:49 PM
Yeah could be.. the only thig that threw me was the wiring colour codes didn't match up with haynes book of lies so I'll have to revert to tracing the wires through the loom... thanks for checking though
Old 8th October 2012, 01:34 PM
OK... mystery solved, it's the cooling fan relay... the fuse is in a slightly differetn location to the haynes book of lies but traced the other wires back to rad fan etc
Thanks all
