Old 1st April 2011, 02:06 PM
Ashtonr Ashtonr is offline
Default Mushroom orientation
Hi Could anyone advise in which direction the offset on the mushroom inserts is meant to point ? it appears to point towards the back of the upright or into the centre of the chassis from the picture on page 73
Regards
Rob
Old 1st April 2011, 02:20 PM
james3004's Avatar
Centre - Front I think
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 1st April 2011, 03:58 PM
Regards
Rob
On that page (#73) it states in the text of paragraph 3, "The hole must be tight in the suspension upright with the hole at the front."
Old 1st April 2011, 04:29 PM
Brilliant thanks for this
Old 1st April 2011, 07:35 PM
It gives a good amount of self center at the front and after IVA move them to 11 o'clock on the left one and 2 o'clock on the right to give better feel to steering and better handling.
Dont forget to provide some locking device for IVA.
Old 1st November 2012, 08:13 PM
jps jps is offline
Is the locking (which I assume is - drill through the upright into the mushroom, tap and secure with a bolt) considered superfluous?
I am struggling to imagine how you'd secure it, then turn it and resecure it...
Old 1st November 2012, 09:48 PM
BenBrooks BenBrooks is offline
sorry to jump in but I'm at the same stage. I know the mushrooms are meant to be tight but i can barely fit mine in at all which would be fine if i can get them spot on but i'll never be able to move the orientation of the hole as you suggest. How are yours for going in?
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/
Old 1st November 2012, 09:58 PM
will_08 will_08 is offline
have you reamed the uprights?
there is a reamer that does the rounds if you search the previous posts m8
Old 1st November 2012, 10:00 PM
here to be exact
http://www.haynes.co.uk/forums/showt...ghlight=reamer
Old 1st November 2012, 10:11 PM
he's talking about the whole mushy
