Old 1st November 2012, 10:14 PM
will_08 will_08 is offline
Im losing the plot, ignore me
Old 1st November 2012, 10:31 PM
BenBrooks BenBrooks is offline
had me confused for a sec then. no worries.
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/
Old 1st November 2012, 10:34 PM
Originally Posted by flyerncle View Post
It gives a good amount of self center at the front and after IVA move them to 11 o'clock on the left one and 2 o'clock on the right to give better feel to steering and better handling.
Dont forget to provide some locking device for IVA.
Please forgive me if this is a dumb question but is there a reason they're not symetrical.
Old 2nd November 2012, 12:05 AM
As far as I know it helps with the self centering along with other settings (caster,tyre pressures)
Old 2nd November 2012, 10:10 AM
Originally Posted by jps View Post
Is the locking (which I assume is - drill through the upright into the mushroom, tap and secure with a bolt) considered superfluous?
I am struggling to imagine how you'd secure it, then turn it and resecure it...
Hi jps, it looks like your question has been overlooked...........
Yes you do need a secondary fixing for IVA, get them in the right position for the IVA man then drill straight through the upright and mushroom and tap it M6 - from the rear there should be enough room. Put in an m6 bolt. Post IVA turn the mushies to where you get the feel you want then do it again. I've had a mushroom come out, luckily while going slowly round a left hand turn with my daughter in the car. It was an eye opener at the time so always make sure you have a bolt through there just in case.
Regards........AndyH
Old 8th November 2012, 03:50 PM
jps jps is offline
Cheers Andy - I think otherwise I would have thought the fixing was 'just for IVA'!
